Troubleshooting Hardware
roboRIO 2.0 will not turn on or power up
M/N = roboRIO 2.0
P/N = 133340B - 01L
S/N = 3249457
Acquired from AndyMark September 2022. Order # EJDZDSK
It will not power on. Verified power at input is 12.2V with multimeter.
Opened and inspected for debris causing shorts. Found none. Used compressed air and vacuum to insure no debris.
Still dead.  No power light. No other lights.
Please advise.
(2,021 Views)
Hi Paullaux, thank you for posting on the forums. I'm Matthew with NI.
Can you double check the polarity? (positive to the "v", and ground to the "c").
I'm not sure this can cause the behavior you're seeing, but it has solved a lot of other booting problems -> Did you image the SD card using either BalenaEtcher or the Raspberry Pi imager as described here using one of the .img.zip files?: https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/roborio2-imaging.html
(if so, which imager did you use?)
(2,013 Views)
Yes. Verified polarity. + terminal (V) is "top" pin and - terminal (C) is "bottom" pin.
Behavior is same if SD card is present or not.
We used Balena Etcher.  Previous unrecoverable error with this roboRIO was SD related, but this is very different. No power at all.
We do not have another RIO 2.0 to test card with - only card reader on laptop. Students tell me it is good and not issue.
(2,002 Views)
Just to sanity check, nothing is connected to the unit besides power?
(1,998 Views)
Correct.  In pits Team 148 helped us verify RIO is dead.
Now back in our shop we have a test bed with a PDP, VRM, breaker switch and RIO.
Powered up - roboRIO v1 powers up.  roboRIO 2.0 is dead.
(see pics)
(1,992 Views)
guess the first attempt to attach pics didn't take. Here they are
(1,990 Views)
I sent you a private message to discuss next steps.
(1,988 Views)
