Troubleshooting Hardware
roboRIO 2 not turning on
Hi, we are FRC team 5549. We bought a new roboRIO fairly recently (about 2 months ago) and so far it has worked well. However, when we tried using it a on new robot we are building, it would not turn on. We looked at the port on the PDH that the rio was plugged into and we realized the fuse on that port was blown. We suspect that this could have caused our roboRIO problems. We tried powering the rio on by connecting it to an old, working PDP we had and it still wouldn't turn on. We also tried cleaning out the SD card slot and no luck there as well. Any suggestions?
GR
(425 Views)
I hope you are doing well.
My name is Thays Molina, from NI.
I have sent you a direct message with further steps.
(392 Views)
