Troubleshooting Hardware
roboRIO burnt part causing short errors?
After using this roborio for our robot, we got errors for a short on the user rail, and the DIO pins weren’t working, and then when we took the roborio out of its case to clean it, there was a part on there that looked burnt. After cleaning the roborio, the short error did not go away, so would the burnt chip be the issue?
(1,097 Views)
Just sent you a message.  Let's talk about getting a replacement there 😃
(991 Views)
