UI Interest Group Discussions
Button animation on mouse-over event
Hi
I'm trying to upgrade front panel of my application by adding some cool stuff, like buttons that have a mouse-over animation.
The application contains modules (about 20) that are communicating using queues and notifiers and using about 15 buttons.
I'd like to be able to create fast way to update those buttons without disturbing communication. I don't want to put a mouse over event in every module for obvious resons.
I know, that's what xcontrols are for, but I've heard a lot of bad opinions about performance of those and before I'll start to develop those, I want to make sure, this is the way to go.
On the other hand I could have a subpanels with running vi's instead of buttons, that can send dynamic events.
Is there another, better way to do it?
Which one is the best?
Message 1 of 21
(16,582 Views)
You can change the image skin of each state of a control.
A system control has 6 states, True, False, True depressed, False depressed, True hover, False Hover
You can change an image skin to an animated gif.
If you replace the False mouseover state to an animated gif, then the button will show and play its animated gif
Also, gif images also support alpha blending
I'll throw a demo together in 10 minutes!
_____________________________
- Cheers, Ed
Message 2 of 21
(13,975 Views)
This sounds very interesting.  I'd love to see the demo!
Patrick Allen: FunctionalityUnlimited.ca
Message 3 of 21
(13,975 Views)
Anyone know how I can add an attachment to the discussion?
- Cheers, Ed
Message 4 of 21
(13,975 Views)
It looks like if you click "Use advanced editor" at the top right of the reply box there is an attachment section.  Not sure if it works though.
Tim Elsey
Certified LabVIEW Architect
Message 5 of 21
(13,975 Views)
The attached zip has a few png files, an animated gif, the custom control and a demo VI.
I have edited the control state skins with various images of an amusing dancing banana.
Cheers,
Ed
- Cheers, Ed
Message 6 of 21
(13,974 Views)
Hi Ed,
Where is the control state skins property? I can add the image for true, false and decal, but can't seem to find the option to edit the image when the button is hovered over.
Cheers,
Greg
Message 7 of 21
(13,974 Views)
Don't worry, I found it. Definitely need to find a place to add dancing banana's to my next application!!!
Thanks for the example.
Cheers,
Greg
Message 8 of 21
(13,974 Views)
A more useful (but less exciting) example on button states:
- Cheers, Ed
Message 9 of 21
(13,974 Views)
Ha!
Omg this is perfect. I was so worried, I'd have to do it some wierd complicated way.
This is exactly what I was hoping to see.
(I'm not talking about dancing banana)
Thank you
Message 10 of 21
(13,974 Views)
