UI Interest Group Discussions
Flatline Controls
I've recently built a set of custom controls to use in my application that follow the recent "flat" or "near-flat" style, called "Flatline".  Available on LAVA and the LabVIEW Tools Network.
Image 1: The Flatline controls do away with the "chrome" of earlier control sets, replacing it with mostly simple shapes, plus ocassional minimal 3D effects to let the User identify what is a control (note the slight lighting effect on the buttons above).
Image 2: Various other controls.  The "Boolean" slide switch shown has more 3D effect than other controls, as it is hard to make a flat switch that is immediatly identifiable as a switch by the User.
Image 3: An example (flat) array of clusters, showing the use of the "underline" style of control to reduce clutter.
Message 1 of 21
(17,533 Views)
Well done! I like the look in the screenshots. It can be a challenge to make applications that aren't instantly recognized as "made with LabVIEW". Not that it is a requirement, but variety and professional looking applications is nice. With these front panel objects and a little change of the background colors it should be much easier to make something modern.
Message 2 of 21
(15,247 Views)
Thanks.
If you download and try it out, please give feedback.  Customizing LabVIEW controls is an exercise in compromise, one has to trade off one thing for another, and I may not have made the right choices for everyone.
Message 3 of 21
(15,247 Views)
Outstanding...!!
Perfect combination of all required controls.
All the controls look good..what I personally liked and required most of the time is the checkbox and it looks cool..!
Message 4 of 21
(15,247 Views)
This is a fantastic set of controls - I also am a big fan of the flat style, particularly when I need I like a cluster of controls to look more cohesive. Have you considered adding this suite to the LabVIEW Tools Network?
Rick C.
Message 5 of 21
(15,247 Views)
One thing I've noticed so far is that the buttons are set to "latch when pressed". I like the feel much better when set to "latch when released", and it allows you to see that intermediate image of the button being depressed when used as an event trigger.
Message 6 of 21
(15,247 Views)
Your right.  I'll change them all to latch when released.
Message 7 of 21
(15,247 Views)
unable to install it in LABVIEW2013 via jki vi package meneger.why?
Message 8 of 21
(15,247 Views)
I've installed it in 2011, 2013, and 2015 successfully.   That's using VIPM 2016.  Try upgrading if you are using an earlier version of VIPM.
Message 9 of 21
(15,247 Views)
Very nice job and I really like it. Is there any chance you could also create Waveform Graphs and Charts? (Especially stacked charts)
__________________
Engage! using LV2015
Message 10 of 21
(15,247 Views)
