UI Interest Group Discussions
Graph Palette like control
I am trying to implement Graph palette like control for my application.
Graph palette has 3 controls - cursor, zoom and hand tool. Cool thing is the zoom control. When you click on that - a picture menu(like, picture ring control) pops up. How can I implement a control like this?
Ritesh
Message 1 of 11
(8,127 Views)
First thought: place the pop up controls on a one-page tab control and use the "visible" property node of the tab control. To make it cleaner and reusable, I'll bundle the whole thing into an X-control.
Message 2 of 11
(5,234 Views)
You have options:
  1. Use a pict ring control (you mentioned this).  You can screen grab the graphics from the NI control if you do a print screen while the menu is shown.
  2. Create a custom dialog with multiple buttons and the pictures as button graphics.
  3. Create a custom dialog using a picture control with all the graphics, and location to pick the one clicked on.
The functionality itself is switched using the Palette»Active Tool graph property.
Message 3 of 11
(5,234 Views)
Hi Ritesh,
don't create multiple posts!
Usually you should ask such questions (only) in the forum...
Message 4 of 11
(5,234 Views)
GerdW - You're right that double-posting is generally bad form, but where you ask a question depends on the type of question being asked. The forums are good for technical support, but NI Community is best for high-level questions about programming approaches.
Message 5 of 11
(5,234 Views)
Hi there,
I created an XControl which has the functionallity you describe.
I showed the functionallity in a gif image:
Here is the link:
http://dl.dropbox.com/u/67794116/Custom%20graph%20palette.zip
You can change the visual appearance by replacing the image of each element (Swipe data, Scale Box, etc.)
Message 6 of 11
(5,234 Views)
hi leonkec,
There is a missing vi from the xctl called Set origin from VI child to zero.vi. Can you reupload it please? Thanks.
Message 7 of 11
(5,234 Views)
@ Rando
Added the missing VI to the zip file and reuploaded it. It should now work.
Message 8 of 11
(5,234 Views)
Hi Rando,
Did you try it? What did you think of it? What would you like to see improved?
Greetings Leon Cranshof
Message 9 of 11
(5,234 Views)
Hi
I would like to try it, but am currentlty using LabView 2010. Can you please downsave it to 2010 version?
Thank you
reto
Message 10 of 11
(5,234 Views)
