UI Interest Group Discussions
How do I Vertically Center Text in a Control?
   Couldn't find an answer in a forum search. Anybody know how to vertically center text in a System Ring?
Message 1 of 8
(14,473 Views)
I would like to know it too!
+++ In God we believe, in Trance we Trust +++
[Hungary]
Message 2 of 8
(8,672 Views)
Unfortunately, I'm fairly certain that LabVIEW does not provide a way to center the text in a ring control vertically.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 3 of 8
(8,672 Views)
There is currently no way to vertically center the text in a system ring.  You can fake it by adding extra carriage returns in the ring text:
Note that when you do this, the extra carriage returns appear as spaces in the ring text when the pop-up ring is visible:
Other than this, the only other way to accomplish what you want would be to create a picture control that behaves like the ring. Painful.
Message 4 of 8
(8,672 Views)
I haven't tried this, but can you do this in a .NET or ActiveX ring (or combo box, which I believe is the name used for the equivalent control)? This will make the code Windows only.
___________________
Try to take over the world!
Message 5 of 8
(8,672 Views)
Have you tried resizing and repositioning the "Ring Text" part usng the Control Editor?
Message 6 of 8
(8,672 Views)
Jack - That solution works as long as you know the text will always be one line, but multi-line text will be cut-off.
Christina Rogers
Message 7 of 8
(8,672 Views)
I think centering vertically should be added to LabVIEW. When you agree then please vote for http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-vertical-center-for-string-indicators-and-don-t-di...
Message 8 of 8
(8,672 Views)
