UI Interest Group Discussions
Process control icons
Years ago (probably in LabVIEW 3.x or 4.x) there existed a plethora of controls with pretty icons for process control functions. There were pumps and pipes and valves of various colors, sizes and orientations. Does any one else remember these? Were they only for the Macintosh environment? What ever happened to them? Have they been turned into activeX controls and hidden in the "Measurement Studio User Interface ActiveX Library"? Is there a library somewhere with controls/indicators like those? Or perhaps just the pictures that we can paste into our own pict rings or booleans?
(8,985 Views)
Hi Paul!
Take a look at the DSC module... It may contains all icons you may want !
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(4,351 Views)
I think you are referencing the Automation Symbols Toolkit, which indeed have been moved into the LabVIEW DSC module.
There is also the option of using the ActiveX Automation Symbols Toolkit. While it is designed for use in Visual Basic, you could use the controls in the ActiveX container in LabVIEW.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(4,351 Views)
