UI Interest Group Discussions
TestStand User Interface using C#
I am trying to modify the sample TestStand 2016 C# user interface code to run 1 sub sequence.  I am able to change the 'Parameters' before running the sequence and I can execute the sequence, but I can not get access to the "Parameters" which have been modified by the sequence back into the C# code.  Can anyone help?
Here are the parts of the code:
this.axSequenceFileViewMgr.Sequence = this.axSequenceFileViewMgr.SequenceFile.GetSequenceByName("zzTestSeq");
this.axSequenceFileViewMgr.Sequence.AsPropertyObject().SetValNumber("Parameters.SetPoint", 0, 149.0);
Execution ex = this.axSequenceFileViewMgr.Run();
In this example the zzTestSeq changes the SetPoint parameter from 149 to 321, but I can not access the Parameters.SetPoint after the Run() command executes.
If I do this:
val = this.axSequenceFileViewMgr.Sequence.Parameters.GetValNumber("SetPoint", 0);
I get the 149 back again.
Robert
Message 1 of 1
(3,955 Views)
