UI Interest Group Discussions
Transpose or rotate a graph?
How easy it would be to create a vertical graph, hence, the data points are on the X axis and the time is the Y axis, where the left top corner of the graph is the 0,0 point, so the graph will be drawn downward with time.
(4,084 Views)
You can use an XY Graph.  If you are using waveforms, it is a bit more difficult, as you would have to generate the X data, but if you have the X and Y, just swap it and use the XY Graph.
(2,939 Views)
