UI Interest Group Discussions
Valves, pumps, and pipe UI Controls
Are there any free UI controls available like the valves, pumps, pipes, etc. found in the DSC module ?
Thx
Message 1 of 11
(17,028 Views)
Yes, provided that you can find an OLD version of LabVIEW.  I believe it was version 4. After that it became a separate package.
Message 2 of 11
(8,915 Views)
Thanks Paul,
I don't have the older version.  Also, if I could get my hands on an older version I don't know if its possible two install versions without problems.
Message 3 of 11
(8,915 Views)
Not the full set, but..
You can find a pipe in the attachments in this post.  You can right-click to add vertical / horizonal sections.  There is also a few decorations in another attached post in that thread.
Pipe
Decorations
Peter D
Message 4 of 11
(8,915 Views)
Thanks, I believe I can use the decorations to customize controls.
Message 5 of 11
(8,915 Views)
thank u very much
Message 6 of 11
(8,915 Views)
I saved the document.  What is the next step ?  How do I pull one of the icons into the controls editor ?
Message 7 of 11
(8,915 Views)
You do copy and paste…
Message 8 of 11
(8,915 Views)
Are there currently any updated industrial control/indicator items available (preferrably for free) for LabVIEW other than thru DSC?  To be honest, the DSC available selections are limited and quite cartoonish.I'd prefer something more modern and professional looking.
Message 9 of 11
(8,915 Views)
Hi Hansel,
you can always customize your controls with any image you like…
Message 10 of 11
(8,915 Views)
