UI Interest Group Discussions
XControls issues
Hello all,
I'm big fan of XControl. I think this is one of the best features added to LabVIEW when LV 8.x version was released.
I've used a lot XControls in my dev and you can see an example here.
However I'm quite frightening by some issue on the memory management in all LV version and on the property/method creation in LV2010.
These issues are discuss on LAVA forum in the following posts :
  1. http://lavag.org/topic/13340-unable-to-create-xcontrol-properties-in-lv2010/page__view__findpost__p_...
  2. http://lavag.org/topic/13317-bug-x-control-memory-leak-with-large-data-array/page__view__findpost__p...
I don't know if the LabVIEW R&D is aware of these issue but I hope they will be fixed in SP1 version of LaVIEW 2010.
Regards
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Message 1 of 1
(7,338 Views)
