UI Interest Group Documents
can any one help me how i can do as this tab , speacially how i can add picture to icon taps
thanks
Comments
Thoric
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
on
If you search for "image in tab control" you'll find this document.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Zbigniew_StS
Member Member
Member
on
There is an option avaliable when you customize Tab Control, so:
1. Right click at tab control > select Advanced: Customize...
2. In control edition window from menu select: Edit: Import Picture to Clipboard...
3. Select picture from yours computer
4. Back to control editor window: select tab at tab control and : Advanced: Tab Layout: Image and Text...
5. Advanced: Tab Layout: Import Picture from Clipboard
Done.
Regards
Mikrobi (Zbigniew St. Sobków)____________________________________________________________
"You can lead a horse to water, but if you can get him to float on his back you've got something."
BasvanDijke
NI Employee (retired)
on
Step 1: Edit>>Import picture to clipboard
Step 2:Picture on tab.png
Olivier-JOURDAN
Active Participant Active Participant
Active Participant
on
To add pictures to tabs :
  1. Right clic on tab
  2. Select Advanced >> Tab Layout
  3. Select the option you want
Regards
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
K1200LT_rider
Member
Member
on
WG-
Member
Member
on
Question and if you want to have the tabs from the tab control not above bot at the left side (as in the picture) what do you do then? Xcontroll I guess..?
eng.3zam
Member
Member
on
alot of thanks to all
but what about the horizontal text when the tab location in left or in right ??
i wait your help
thank
Thoric
Trusted Enthusiast
on
No, you just set Advanced > Tab Location > Left
Thoric
Trusted Enthusiast
on
I think the text in your example is a part of the image, not the tab page label. I don't believe there's a way to reorient the tab page label text so you'll need to hide them and superimpose the labels into your pictures.
BasvanDijke
on
Contributors
