Create_Scale_LV2010 v1.0.0
Author: Prabhakant Patil
LabVIEW Versions: 2010
Dependencies:
1. NI DAQmx Device Driver
2. OpenG Application Control
3. LabVIEW Runtime engine 2010
Description:
This example is used to create / update / delete daqmx scales. Using this variuous types of scales can be created like Linear, Map Ranges, Polynomial and Table.
Also using this you can delete or update existing scales.
If you have any suggestion, please let me know
The Link for DAQ Scale is
https://decibel.ni.com/content/docs/DOC-23044
Regards
Prabhakant
I normally use NI Measurement & Automation Explorer to do this. Is there something wrong or difficult with using MAX for this task?
It is not difficult with using max.
It will give you flexibilty, when you creating and executable and you dont want user to do settings from Max.
Hi Prabhakant_Patil,
Is this method applicable for scaling current value (mA) to deg F? I only see value of current on my screen and not sure how to scale it to different units like deg F, psi, deg C etc.,
By the way, I am using NI-cDAQ-9174 hardware for data acquisition.
Maitrey
