UI Interest Group Documents
Green style Flat UI Control Suite
Hi all,
I've designed a green style flat UI control suite, which maybe of great use for those developers who want their applications to have a modern look!
Credits:
  • All  the icons are made by MetroStudio. MetroStudio is a free software product by Syncfusion.inc
  • I suppose I should credit microsoft with the inspiration.
Installation Instructions:
Download the vip package and install with VIPM, or you can download it directly from VIPM.
Software license
The code referenced in this document is distributed under the NATIONAL INSTRUMENTS SOFTWARE LICENSE TERMS - www.ni.com/legal/license/
Comments
Ajay_MV
Active Participant
Active Participant
on
Looks pretty.  Are you developing it now?
Ajay MV
huangjinghit
Member
Member
on
Thanks! It's developped and you can download it directly from VIPM online!
AJJSYCSA
Member
Member
on
Is it possible you to share it in LV2014 version?
huangjinghit
Member
Member
on
Since I just have LV 2015 installed in my PC, it is impossible to build vip package that supports LV 2014. However I'll try to figure out other ways.
AJJSYCSA
Member
Member
on
No problem, thank you.
Chrisrobbins
Member
Member
on
Great job! Thank you for your contribution.
JensG69
Active Participant
Active Participant
on
If you are willing to post the source-code:
Save -> For previous version
Save it as far down as possible and upload a zip-file of your project.
That Control Suite would a great addition to other LabVIEW versions too (not just 2014...)
Kudos are welcome...
FluXay
NI Employee (retired)
on
Great job Jing! We'll probably build our new QView plugins based on this:)
kaka2010f1
Member
Member
on
Contributors
