Hi All
The Vista Style Transperant Buttons are developed.
Update:- Installer Is included
Please Give comment on this Library
License - General Public License: http://www.gnu.org/copyleft/gpl.html
Regards
Prabhakant Patil
Hey, nice work!! How do I install it?
Just Download Zip File.
Extract It and Copy This folder to User Library.
Required Labview Version is - Labview 2009 or above
It's as simple as you said, previously I had renamed the Vista Small folder to Vista...
All Icons are Free
But it is not for commercial Applications
Good work; It is very helpfull.
Thanks ![]()
Library has been Updated
Just try it ![]()
It's Great
Thanks ![]()
You've stated that these cannot be used in commercial applications. Is that position likely to change at any point?
Kindly download from following link.
https://decibel.ni.com/content/docs/DOC-16365
https://decibel.ni.com/content/docs/DOC-16710
Icon used in this library are free.
You can use it. ![]()
Prabhakant
Prabhakant
If you're only going to make very minor changes can you please check the 'minor change, don't send notifications' checkbox.
Oh, My God, this is amazing, thank you...
Prabhakant: If this document contains not-for-commercial-use content then you must state this in the document, clearly and somewhere easily identifiable. You have a link to the GPL license but this isn't enough, you need to state the works are not for commercial use.
