Following up from some other posts about using .NET controls in LabVIEW I figured I'd post this example I wrote a while ago (disclaimer - I haven't done extensive testing and I really through it together in a hurry so no promises of quality).
Essentially I have created an XControl which hides the associated complexity of using .NET controls in LabVIEW. If you plan on using a control more than once it's probably worth while -- XControls are fairly simple to use for use cases such as this gauge.
In order for the demo to actually work you'll need to install the Dundas Gauge for Windows Forms package. A free evaluation is was available here - http://www.dundas.com/Components/Downloads/index.aspx#gauge
Unfortunately the .NET control I was using is now EOL and no longer available.
Things you should know about XControls:
First of all, Great post ![]()
I have only a few notes, you can make arrays of XControls, just put the XControl in a cluster and that cluster in a array
. Also you can disconnect your XControl so you can edit them at runtime. You need to close all references when you want to relink your XControl.
Great Post!
Thanks for sharing, but the link: http://www.dundas.com/Components/Downloads/index.aspx#gauge does not work!
Unfortunately Dundas Guage appears to "End of Life" due to acquisition from Microsoft
. I'll modify the post to reflect that.
