USRP Software Radio
2901 stream - what are the maximum streaming rates on 2 CH RX Only with LabVIEW?
(5,175 Views)
This is largely machine dependent.  Some machines max out at 5 MS/s while others might exceed 20MS/s.  Adding processing can adversely impact the streaming rates.
Erik
(5,169 Views)
I hit the wall at 8 MHz but I'm using the 1gbit ethernet interface. What are you using?
(5,106 Views)
I thought the 2901 only had a USB3 interface?
(5,104 Views)
It does, he must be referring to one of our other devices.
(5,080 Views)
