USRP Software Radio
2920 conversion to 2921 (and back)
Does the USRP-2920 contain a WBX 50-2200 MHz Rx/Tx (or similar) daughterboard? If yes, can this daughterboard be replaced (on a temporary basis) with Ettus' XCVR2450, in order to convert the 2920 into a 2921? If yes, what additional software / hardware (dual band 2,4 and 5 GHz antenna, obviously) is required? Thank you for any information you can provide.
(6,631 Views)
The 2920 and 2921 have been fully tested and certified in their respective configurations. Changing this configuration is not warranted or recommended.
As you suggest they share a common motherboard architecture and use unique RF boards.
(6,626 Views)
Accepted by topic author ni-colas
Thank you for the quick answer. Yes, you are right, testing and certification is important.So, this doesn't seem to be a good idea.
(6,616 Views)
