USRP Software Radio
Angle of arrival MUSIC algorithm
I am not intimately familiar with the AoA code posted on the community website.
All I can add is that if you're not also simultaneously measuring a reference in all your receive radios...then the phases you measure from your source/object to each radio will be meaningless.
Message 11 of 12
(2,243 Views)
Hi cochenob,
Thx for your reply.
I though that the synchronous phase algorithm always simultaneously measuring because, on the labview code for signal processing, the code for phase synch appear right after fetch_data.vi. So the AoA algorithm will process received signal after it have been synchronouse. Am I wrong ?
Message 12 of 12
(2,163 Views)
