USRP Software Radio
B210 to receive two channels with UHD_RX_CFILE
I'm trying to receive two channels simultaneously (same frequency) with a USRP B210. That works nicely using gnuradio and writing the RX data to complex binary files. Is it possible to do the same using the command line and UHD_RX_CFILE?
Thanks!
Maasch
(4,470 Views)
anyone share with me a VI with Implementing 2x1 MISO system with LabVIEW and NI USRP 2921 using Alamouti code?? I need problem with the estimation channel in the receptor, i used the alamouti code with 2 antennas trnasmitter and one antenna receiver
(3,484 Views)
