USRP Software Radio
Bandwidth from X310 with 2 UBX -160
I was playing with the X310 with 2 x UBX-160 using the LAbview USRP example ' Spectral Monitoring (interactive). I am trying to figure how much bandwidth is available for spectral sensing.
I get the following error -1074118610 when I run with the vi with 100 MHz or 200 MHz .
"niUSRP Fetch Rx Data (CDB WDT).vi<ERR>The received data is out of sequence. This may be a symptom of overflows due to an inability to maintain streaming at the specified IQ Rate, or rearrangement of packets by an ethernet adapter or network switch."
Any ideas on how to fix this.
Message 1 of 1
(2,675 Views)
