USRP Software Radio
Calculate BER between two USRP RIOs
I'm PhD Student I have not much experience about USRPs. I'm new at this research area.
We have two USRP 2943R. We have NI Labview 2014 , including Modulation Toolkit,USRP intrument drivers.
We  tried NI Labview 2014 niUSRP- Labview Modulation Toolkit Examples. We used two USRP, one of them transmitter another is receiver. We understood niUSRP EX PSK Tx.vi and   niUSRP EX PSK Rx.vi examples. We runned this Vis simultaneously. But I wonder that how could we calculate bit error rate while , two simultaneous vi are runnig.
I know that MT Calculate BER .vi function block, where we should  connect this block on  niUSRP EX PSK Rx.vi . Should we have to synchronize to USRP R for calculate correct BER. Is it possible? We cannot find examples about USRP that calculate BER.
Could you help us please?
Best Regards..
Message 1 of 8
(5,625 Views)
You may find this example on DPSK helpful as it calculates BER in a fashion that you might be looking for: http://www.ni.com/example/30126/en/
As well, you can look up some more information on usage of the Modulation Toolkit's BER VIs with this help page (even though its targeted for LabVIEW Comms, it has a similar implementation in regular LabVIEW): http://www.ni.com/documentation/en/labview-comms/1.0/mt-node-ref/mt-calculate-ber/
John Gentile
Applications Engineering
Message 2 of 8
(5,579 Views)
Thanks for your reply
These examples are concerned about simulation.  Where do I find BER  Examples that use USRPs
Message 3 of 8
(5,546 Views)
As an aside, there are multiple forum threads and posts about this same question and unfortunately the answer is that right now there is no explicit example that just calculates BER. BER and its calculation is very dependent on your modulation and demodulation scheme, so I would suggest you explore how you would calculate BER mathematically given your specific scheme and then work with Modulation Toolkit to implement this.
Message 4 of 8
(5,520 Views)
hey friend, did you find out the way to do ber?  I got the same question as you do. just use basic bpsk, then I want to see the ber. thank you.
Message 5 of 8
(5,035 Views)
Unfurtunately,I did not implement ber on real time rios
Message 6 of 8
(5,025 Views)
hey, friend. Check this link. It seems that this guy did the ber right, but he want to do something more, and he failed.  please let me know what you think? because I am working on ber as well.  thank you.
http://forums.ni.com/t5/USRP-Software-Radio/Direct-sequence-spread-spectrum/m-p/3285766
Message 7 of 8
(5,019 Views)
My friend, I also post something about the ber problem. if you have any updates, please give me a reply here.  thank you!
Message 8 of 8
(5,015 Views)
