USRP Software Radio
Can 4Rx simultaneously function in X310
Hi, in the exhibition of MILCOM 2016, I stopped by the booth of NI. They demo a DOA estimation with 4 antenna using X310. But checking the data sheet of X310, I found that X310 only has two RF chains, so how the DOA demo use 4 antenna based on one X310? Thanks,
(4,492 Views)
The X310 is a motherboard, which has two slots for daughterboards. The demo uses two TwinRX daughterboards, which each have two RX channels.
(4,470 Views)
Gotcha. Thank you for your information. BTW, what are the development tools for the X310 and Two TwinRx? Labview only or also good for GNURadio?
(4,464 Views)
No problem! There are several development toolflows for the X310 plus TwinRX. You can use GNURadio and The Mathworks MATLAB & Simulink to program the device now.  NI-branded HW (the USRP 2945 and 2955) will arive in mid-January and support LabVIEW and LabVIEW FPGA. The NI-branded HW will also have CE/UL certification and NI support.
(4,447 Views)
Hello, USRP X310 changes 2 RX channels into 4 input RX channels. What changes need to be made to the underlying VERILOG program?
(3,660 Views)
Hi naniandechunyang,
Could you be a little more specific regarding what Verilog program you are referring to?
(3,633 Views)
