USRP Software Radio
Can NI-USRP be worked on GNU Radio?
I am trying to build FPGA/Firmware images on my NI USRP 2930 to make it work with GNU Radio framework. I have tried with the Firmware and FPGA images of n200, n210 and b200 to no avail. The error that I have been encountering in the process is : "The FPGA image selected is not valid for the selected hardware. The revision numbers do not match" Can anybody help me out in this process? Thanks in advance.
(3,520 Views)
Hi Ammar95,
I reccomend contacting Ettus support. Using the GNU Radio toolchain is certainly possible on a USRP 2930, but it requires some additional steps that Ettus will be familiar with. For reference, your 2930 is a N210 with a WBX daughterboard.
(3,506 Views)
