USRP Software Radio
Cannot find GPSDC
I have USRP two 2932, which has internal GPDSC by default.
One of them runs perfectly while using USRP examples that use GPS, but another says "GPSDC not found". Both are same USRP. I also have tried changing IPs, Updating the firmware and change the cable etc, but it doesn't seem to work and gives the same error.
Please help me resolve this issue asap, i guess it might be because of flush buffer. (Not sure)
Regards
(2,629 Views)
Hi ManasNyati!
The error you see seems quite odd, I am afraid I did not find any similar issues on our internal database, so it might be better to switch to email or phone support instead.
Can you please share a screenshot of the error message? Are these brand new USRPs? If they have the exact same firmware and one of them fails in the same PC where the other works, I can only guess something is something wrong with the USRP (maybe a hardware issue) so it might be better to troubleshoot through a different communication path
WenR
(2,568 Views)
