USRP Software Radio
Cannot receive signal in LabVIEW when using N210 with WBX as a single device
I am using N210 with WBX daughterboard as a single device in LabVIEW 2018.
I tried to run the example from https://decibel.ni.com/content/docs/DOC-18801
I have no problem in transmitting. However, I cannot receive the signals.
I got this error
Error -1074118627 occurred at niUSRP Initiate.vi
Possible reason(s):
A runtime or configuration error occurred.
Code: 2786
Details: LookupError: Path not found in tree: /mboards/0/dboards/A/rx_frontends/0/sensors/lo_locked
When I tried other example from USRP example, still I got the same problem.
Is there anyone can help me regarding this?
Thank you so much in advance.
Message 1 of 1
(1,232 Views)
