USRP Software Radio
Clock Synchronization
Hi!
I want to synchronize two transmitting USRP boards so that the receiver receives both their signals at the same time (they have to be synchronized on bit level). I'm using an improving ALOHA algorithm which is working based on knowing one signal and detecting the other from that.
I am using USRP1 boards, which they don't have any special things to use for synchronization. Is there anything I can do?
(3,762 Views)
Hi Nightstalkerman,
Are you using LabVIEW on the USRP1 ?
(3,746 Views)
Hi!
I'm currently using simulink, but if my problem can be solved using labview, I'll try that.
(3,740 Views)
LabVIEW makes using USRPs easier, but I don't believe the USRP 1 is compatible with LabVIEW. I recommend contacting Ettus support as they will be more familiar with both the hardware and software you're using.
(3,734 Views)
