USRP Software Radio
Configuring USRP N210 and BasicRx for 2 input signals
Dear All,
We are developing some projects for analog signal acquisition using ettus USRP N210 and BasicRx daughterboard.
Is there any example or specific configuration so that one USRP N210 and basicRx daughterboard can be used for two different signals (in real mode)?
Any suggestions is very much appreciated.
Thanks.
(2,849 Views)
Hey Centrums,
The basicRx daughterboard isn't used in any of the NI USRP products, so you're probably going to have better luck asking questions through the Ettus support chain: https://www.ettus.com/support. If you're trying to use the NI USRP driver in LabVIEW, since you have the directRx daughterboard, it also wouldn't technically be supported.
Cason
NI Applications Engr.
Cassandra Longley
Senior Technical Support Engineer - FlexRIO, High Speed Serial and VRTS
(2,816 Views)
