USRP Software Radio
Connect B205mini via wire (!) to a 5G radio module (like Quectel RM520N-GL)
first many thanks for all the great products you develop!
I want to use the USRP B205mini-i in a use case like
https://asset-group.github.io/disclosures/5ghoul/
I want to connect the B205mini with a 5G radio module (like Quectel RM520N-GL).
I don't want (or can't) use it with antennas,
but I need to use cable for the connection between SDR and radio module.
The radio module has multiple antenna connection,
but usually each one for a certain frequency.
So I want to connect one of the antenna connections of the radio module with the B205mini.
Can you tell me for what connector "ref" is needed (in general)?
I assume I must connect the RX and TX together with 1 antenna of radio module.
But I assume I need some "special things" (sorry I am a software guy) between these 3 connectors. Can you help me to identify what I need
or suggest what I need to use to avoid destroying the B205mini as well as the radio module.
As far as I can see on the video on above page
( https://youtu.be/HN2r6esRDjM?t=671 ),
there are two parameters
in 5G simulator, which could be also relevant for this:
att_tx = 12
att_rx = 12
I hope the above info is useful to suggest me what to use.
If you need more data for the 5G radio module antenna connector,
please let me know which value you need, I have access to needed data sheets.
Many thanks in advance!
Martin
Message 1 of 1
(1,489 Views)
