USRP Software Radio
Creating Installer containing NI-USRP driver VIs
Hi all,
I developed a simple transceiver app using NI-USRP driver. It so happened that I needed to change workstations, and because installing LabVIEW Developement System with all required drivers is tedious, I decided on creating an installer. Unfortunately, in 'Additional Installers' tab of installer build specifications there is nothing related to USRP.
As a result, after installing on a fresh PC and subsequently running the app, a broken arrow is seen with error messages starting with 'Missing external function niusrp2 ....' (see attachement).
Is it possible to find a way around this issue?
My setup is Win10, LV2020 SP1 x64, NI-USRP 20.0.1.
(1,566 Views)
as a workaround you can manually install NI-USRP on the fresh PC.
Kind Regards,
(1,560 Views)
Thank you for your reply.
It is not really an elegant solution, because its adds 6GB (most of which I do not need) onto my 200MB installer, but I guess there is no other way.
(1,506 Views)
