USRP Software Radio
DBL, WDT, CDB ... Switching between Data Types with USRP and Modulation Toolkit
All of these datatypes are variations of the same information.
IQ data is represented as an array of Complex Numbers where each row contains a single antenna channel. (CDB = complex double precision numbers)
The Cluster and Waveform Datatypes contain nearly similar information, however the waveform represents time in a higher precision way.
The attached example demonstrates how to convert between these data types.
Message 1 of 1
(6,665 Views)
