USRP Software Radio
DOA using MUSIC Algorithm
Hi AgentAstronaut !
Thanks for your assistance and help!
Message 11 of 13
(1,426 Views)
Hello AgentAstronaut,
I am currently considering to use a system with 2 synchronized RXs as well, for the DOA implementation.
From the geometrical point of view, the direction based on 2 antennas can be calculated using the standard expression(attached).
MUSIC requires that the number of targets would be lower then the number of antennas used.
As a result, seem to me that using two synchronized antennas should be feasible, and USRP 2901 may answer the clocks/phases requirements.
Would be glad to have your opinion on the issue.
Thanks.
Message 12 of 13
(1,384 Views)
Hi Sen Sen Sen,
I'm not an expert on the MUSIC algorithm by any means but I have heard that you need at least three antennas to get a reading, and four antennas to get a good reading.
I don't really have much more to add than that.
Michael Bilyk
Former NI Software Engineer (IT)
Message 13 of 13
(1,375 Views)
