USRP Software Radio
Data not transmitted between USRPs until ...
Hello Eric,
As you mentioned I even posted my design on machine vision forum here. I am able to somehow solve the avi frame related problem but not completely. Right now If I run AVI frame related code individually it works fine. But when I put it back in main USRP code, the Rx part shows that it receives signal data but does not able to display any thing on the screen.
On the other hand Tx part shows that video and its output array are jerking.
Also I observed that in my main USRP code on Tx side IQ Packet, Packet, and Bit stream indicators (which are at the right bottom on the main block diagram) shows value close to 1000. But when I run the webcam code it shows "0" value for these indicators. Can you guide me how to fix this issue?
Once again many thanks for your support and guidance.
Message 11 of 11
(1,307 Views)
