USRP Software Radio
Do I need to install drivers before USRP 18.1 to use B210?
I have a B210 Rev. 4. I am trying to get it connected in LabVIEW 2017 32-bit, but could not find the device in labview. Here is what I have done:
1. I installed the UHD driver as advised on Ettus website;
2. I updated my USRP driver from 14.0 (I believe) to 18.1;
3. I changed the Device ID on USRP Configuration Utility to USRP2901.
However, when I created the niUSRP Open Tx Session.vi and tried to choose device names, I could find nothing.
I was wondering if I should install all the drivers all the way from 14.0 to 18.1. Also, is there anything I need to do but missed?
Thank you so much
(2,417 Views)
Update:
I tried manually typing the USRP name in the Device Name constant of the Open TX Session vi, and I can use it. Looks like Labview does not recognize and list it automatically on the Device Name drop down menu, but you can still use it.
(2,397 Views)
