USRP Software Radio
Error code 1074118626: The local oscillator did not lock within the alloted time
Hi, I've met some trouble when I was runing the "Wireless video link" example here: https://decibel.ni.com/content/docs/DOC-22728
I was using two 2932 USRPs and they are both connected to a switch, which connects with the computer using a ethernet gigabit cable. When I run this example, I used the  default parameter settings, e.g, Rx/Tx IQ sampling rate: 2M s/sec; Rx/Tx frequency: 915MHz; Rx/Tx Gain: 20dB.
When I try the image transmission in this example, the receive panel shows the following error:The local oscillator did not lock within the alloted time. The error code is 1074118626.
I've searched everywhere and didn't find a complete answer. Has anyone else met this problem and how did you solve it ?
Thank you.
Regards.
Message 1 of 1
(3,761 Views)
