USRP Software Radio
Error in runtime application when using "niUSRP Get Time.vi"
I have a build a runtime application that works fine with the USRP.
i added the function 'niUSRP Get Time.vi" in the blockdiagram and the i get this message when trying to run the executable : (no errors when building)
LabVIEW: Resource not found.
an erreror occured loading VI 'niUSRP Get Time.vi' Labview load error code3:
Coluld not load frontpanel.
If i then add the frontpannel in the build settings i get :
"VI has an error of type 2228. The full development version of LabVIEW is required to fix the errors"
anny sugestions ?
if i remove the 'niUSRP Get Time.vi' in the blockdiagram all works fine again, whats so special with this function?
(6,309 Views)
Hey ORN,
Would you mind posting a screen shot of your block diagram and/or post your vi?  There isn't anything in particular about this VI that would cause it to not work in a run time environment.  However you need to make sure that you have support for NI-USRP 1.2 installed on the computer that you are using.  This feature was added in 1.2 and if an older version of the driver is being used, it would cause an error.
Sarah Yost
Senior Product Marketing Manager
(6,303 Views)
We have escalated this error to R&D.  They plan to reproduce it and answer this post this week.
(6,276 Views)
Hi
Thats fine ,, I use the latest drivers (1.2)Here is the code ,its just for testing & measuring on a triggerpulse :
(6,263 Views)
We can't seem to duplicate the error in LabVIEW 2012.  What version of LabVIEW are you using so we can try that version?  Thank you, Erik
(6,216 Views)
