USRP Software Radio
Failure to get connection between Intel e810-2CQDA2 and x440 SDR
Hi
We have an Intel e810-2CQDA2 board in our PC connected (currently using one cable) to our x440 and we're having problems getting the PC to talk to the x440. We purchased this particular board because it had been tested by Ettus and was recommended on their web site.
We have installed the Intel driver 1.16.3 for the network card and also updated the NVM to the latest version 4.70.
On the X440 we have installed the CG_400 FPGA image to ensure it uses the 100GbE connection. This is confirmed using "uhd_find_devices".
We have a solid green light on the ports for both the network card and the x440 but no flashing activity lights.
On the x440, the output from "ip addr" shows the interface is up and has an IP address:
4: sfp0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc fq_codel qlen 1000
link/ether 00:80:2f:40:95:1e brd ff:ff:ff:ff:ff:ff
inet 192.168.10.2/24 brd 192.168.10.255 scope global sfp0
valid_lft forever preferred_lft forever
inet6 fe80::280:2fff:fe40:951e/64 scope link
On the PC, we have configured an IP address and tried to bring the interface up using:
ip addr add 192.168.10.10/24 dev enp6s0np0
ip link set dev enp6s0np0 up
The output from "ip addr" then shows the device is not receiving any carrier:
3: enp6s0np0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 40:a6:b7:cf:7b:b0 brd ff:ff:ff:ff:ff:ff
inet 192.168.10.10/24 scope global enp6s0np0
The output from "ethtool enp6s0np0" shows unknown speed and duplex settings.
Settings for enp6s0np0:
Supported ports: [ ]
Supported link modes: 25000baseCR/Full
25000baseSR/Full
50000baseCR2/Full
100000baseSR4/Full
100000baseCR4/Full
100000baseLR4_ER4/Full
50000baseSR2/Full
10000baseCR/Full
10000baseSR/Full
10000baseLR/Full
50000baseSR/Full
50000baseCR/Full
50000baseLR_ER_FR/Full
100000baseSR2/Full
100000baseCR2/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: None RS BASER
Advertised link modes: 25000baseCR/Full
25000baseSR/Full
50000baseCR2/Full
100000baseSR4/Full
100000baseCR4/Full
50000baseSR2/Full
10000baseCR/Full
10000baseSR/Full
10000baseLR/Full
50000baseSR/Full
50000baseCR/Full
100000baseSR2/Full
100000baseCR2/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: None RS BASER
Speed: Unknown!
Duplex: Unknown! (255)
Auto-negotiation: off
Port: None
PHYAD: 0
Transceiver: internal
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: no
The output from: "lshw -class network" seems to show the card is trying to operate at 25Gbit/s, rather than the full 100Gb/s - could that be the issue?
*-network
description: Ethernet interface
product: Ethernet Controller E810-C for QSFP
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:06:00.0
logical name: enp6s0np0
version: 02
serial: 40:a6:b7:cf:7b:b0
capacity: 25Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi msix pciexpress vpd bus_master cap_list rom ethernet physical 25000bt-fd autonegotiation
configuration: autonegotiation=off broadcast=yes driver=ice driverversion=1.16.3 firmware=4.70 0x8001f7b4 1.3755.0 ip=192.168.10.10 latency=0 link=no multicast=yes
resources: iomemory:400-3ff iomemory:400-3ff irq:16 memory:4018000000-4019ffffff memory:401c000000-401c00ffff memory:81c00000-81cfffff memory:401a000000-401bffffff memory:401c010000-401c40ffff
Any help would be appreciated.
Best wishes,
Ben
Message 1 of 1
(445 Views)
