USRP Software Radio
Firmware update
While I was uploading a firmware of NI-USRP 2290 a network error occured. Uploading of a firmware was interrupted.
 NI-USRP utility can not find a device and I can not ping the device using previous configured IP address.  uhd_find_device.exe and uhd_usrp_probe.exe can not find the device. After a startup sequence, only led diode F shines.  I am wondering how to upload a firmware?
Thanks for any suggestions,
dd
(5,987 Views)
remove the cover , hold down the little button called S2 and reboot the unit , hold it down until it have finished rebooted.
the the unit will now have default IP address(192.168.10.2) & default FW and FPGA image.
Now you can try uppgrading again
(5,984 Views)
