USRP Software Radio
Frequency drift jumps between two USRPs
Hello, I am relatively new in NI USRP and labview.
I am trying to do a labview program which is able to send a message from one USRP (2920 model) to other one. I programmed it using labview 2012.
I programmed a quadricorrelator for measure the frequency offset.
I programmed another VI which tests my quadricorrelator. This VI measures the frequency using the quadricorrelator and also a NI Phase-Lock Loop (PLL). After a while I get the following:
The measured frequency sometimes jumps from one frequency to another one. I have no explanation. The USRPs are connected each other using the included cable and the attenuator. The ports used are the TX1 and the RX1.
 Why is occurring that? Have I configured properly my pair of USRP?
I attached the VI I used.
Thanks in advance,
Xavier
Message 1 of 1
(6,698 Views)
