USRP Software Radio
GPS did not lock within the alloted time
I am deploying a NI USRP-2920 with NI LabVIEW 2016 and GPS Toolkit v2.0.
After the satellite fix timeout (10 minutes), the system prints the following error message:
<<The GPS did not lock within the alloted time>>
Of course the GPS lock status on the Device is FALSE (NOT LOCKED). I am using the following (attached) VI script. Could please someone help me?
Thank you very much!
(3,463 Views)
Hi Tassos83,
Your code looks correct except I'm not sure why you have the Timebase Clock Source set to internal instead of GPS.
What's the visibility like where you are deploying this device?  Do you have any other GPS devices that you can test at the site to see if they can get a lock?
(3,418 Views)
Nevermind, I didn't notice that you were using the USRP 2920 which doesn't have a GPS disciplined clock.
(3,416 Views)
