USRP Software Radio
Getting RSSI details of USRP 2922
I am testing NI USRP 2922 and want to know whether there is a way to get the RSSI details of the signal.
I basically want to calculate distance between two USRP 2922 devices, is there an alternative method to do that using labview. Is there a block already developed for this purpose.
Any help appreciated.
(2,808 Views)
I would recommend checking out the Tx Continuous Async & Rx Continuous Async examples, which you can find in LabVIEW Communications, Learning -> Examples. If your method is amplitude-based, then you can get the RSSI details by measuring the level of your recieved signal (the examples can be at help). If it's based on the time of flight, you should develop your own code.
Thanks!
(2,753 Views)
