USRP Software Radio
How do I connect x310 with LabVIEW
I believe my connections are correct. I had responses with the following code. However, it did not show up on NI-USRP Configuration Utility. I need to have LabVIEW running with it.
Thanks!
C:\Program Files (x86)\National Instruments\NI-USRP\utilities>ping 192.168.10.3
Pinging 192.168.10.3 with 32 bytes of data:
Reply from 192.168.10.3: bytes=32 time<1ms TTL=32
Ping statistics for 192.168.10.3:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Program Files (x86)\National Instruments\NI-USRP\utilities>uhd_find_devices --args addr="192.168.10.3"
-- UHD Device 0
Device Address:
serial: 30DDAF9
addr: 192.168.10.3
fpga: HG
name:
product: X310
type: x300
C:\Program Files (x86)\National Instruments\NI-USRP\utilities>uhd_usrp_probe --args addr="192.168.10.3"
_____________________________________________________
| Device: X-Series Device
| | Mboard: X310
| | revision: 8
| | revision_compat: 7
| | product: 30818
| | mac-addr0: 00:80:2f:25:71:d1
| | mac-addr1: 00:80:2f:25:71:d2
| | gateway: 192.168.10.1
| | ip-addr0: 192.168.10.3
| | subnet0: 255.255.255.0
| | ip-addr1: 192.168.20.2
| | subnet1: 255.255.255.0
| | ip-addr2: 192.168.30.2
| | subnet2: 255.255.255.0
| | ip-addr3: 192.168.40.2
| | subnet3: 255.255.255.0
| | serial: 30DDAF9
| | FW Version: 6.0
| | FPGA Version: 36.0
| | FPGA git hash: fde2a94
| | RFNoC capable: Yes
| | Time sources: internal, external, gpsdo
| | Clock sources: internal, external, gpsdo
| | Sensors: ref_locked
| | | RX Dboard: A
| | | ID: UBX-160 v1 (0x007a)
| | | Serial: 30D5477
| | | | RX Frontend: 0
| | | | Antennas: TX/RX, RX2, CAL
| | | | Sensors: lo_locked
| | | | Freq range: 10.000 to 6000.000 MHz
| | | | Gain range PGA0: 0.0 to 31.5 step 0.5 dB
| | | | Bandwidth range: 160000000.0 to 160000000.0 step 0.0 Hz
| | | | Connection Type: IQ
| | | | Uses LO offset: No
| | | | RX Codec: A
| | | | Gain range digital: 0.0 to 6.0 step 0.5 dB
| | | RX Dboard: B
| | | Serial: 30D5429
| | | | RX Frontend: 0
| | | | Sensors: lo_locked
| | | | Connection Type: IQ
| | | | Uses LO offset: No
| | | | RX Codec: B
| | | TX Dboard: A
| | | ID: UBX-160 v1 (0x0079)
| | | Serial: 30D5477
| | | | TX Frontend: 0
| | | | Antennas: TX/RX, CAL
| | | | Sensors: lo_locked
| | | | Connection Type: QI
| | | | Uses LO offset: No
| | | | TX Codec: A
| | | | Gain Elements: None
| | | TX Dboard: B
| | | Serial: 30D5429
| | | | TX Frontend: 0
| | | | Sensors: lo_locked
| | | | Connection Type: QI
| | | | Uses LO offset: No
| | | | TX Codec: B
| | | | Gain Elements: None
| | | RFNoC blocks on this device:
| | | * DmaFIFO_0
| | | * Radio_0
| | | * Radio_1
| | | * DDC_0
| | | * DDC_1
| | | * DUC_0
| | | * DUC_1
(2,616 Views)
Did you manage to sort out the issue. I am facing the same issue. Can not configure the USRP X310 by LABVIEW . Hope if any one can help with that please?
(856 Views)
