USRP Software Radio
How to eliminate the noise in the signal received from playback ?
Hi, everyone.
I have one USRP 2930( LV 2015, NI-USRP 14) , and I use the NI USRP Record and playback-I16.vi with  USRP 2930 to record a signal transmitted from other device (center = 119.1MHz / gain = 0 / IQ rate = IQ Samples = 1MHz, the same below), then I use the same  NI USRP Record and playback-I16.vi to record the recorded signal , at the same time use my procedure to receive the playback signal. One SMA cable bought from NI  links with the TX1 and RX2 p...
I find that the there are noise  in my received signal from the power spectrum,  the signal amplitud...damped and the precision is not enough .
I want to know how to eliminate the noise in the signal received from playback, and why there are noise after playback?
Thanks.
(3,765 Views)
Same problem here, any suggestion?
(2,984 Views)
Same problem, any suggestion?
(2,303 Views)
