USRP Software Radio
How to find distance between usrp and the object reflcting its rf wave using 2901 and labview 2014
I am making a long range metal detector that can detect a metal from a maximum of 30 meters.
and i know about this clock problem but i am trying to implement a proof of concept of long range metal detector with bad precision.
now i am thinking of finding the flight of signal by using bpsk modulation.
Message 11 of 12
(1,188 Views)
That's an interesting project. BPSK could help you preserve the quality of your signal, but I don't believe it will allow you to get around the clock problem. Is there a reason you need to know the flight of the signal in order to detect a metal? It seems to me that you can just threshold the magnitude of the return signal.
If you don't care that your flight time will be heavily quantized, then you can use a counter that is hardware-triggered to start counting by the sent signal and hardware-triggered to stop counting by the received signal.
Message 12 of 12
(1,185 Views)
