05-06-2024 12:58 AM - edited 05-06-2024 01:00 AM
I am trying to send and receive frame from NI USRP 2900.
The frame example is FE FE 00 00 00 05 B1 44.
I send the frame with array. I am not sure whether USRP really transmit the data.
How can I check? TX1 RX1 LED is red when I run Transmit VI.
I would like to receive the frame from USRP too but I get 0.
How can I modify my program? TX1 RX1 LED is green when I run Receive VI.
I take reference from the niUSRP EX Tx Continuous Async example VI and the niUSRP EX Rx Continuous Async example VI.
I have attached transmit and receive vi image.
I don't understand LabView so much.
I am new to LabView and this is my first assignment.
Thank you.
05-06-2024 08:49 PM
Hi
You should set the tx gain and the rx gain to around 35dB.
05-14-2024 01:19 AM
Thank you, mikiofuku.
I don't get the result. Still I am trying.
05-20-2024 09:05 PM
Hi
You should breaking down the issue into parts. Problem causes rx side or tx side?
You can transmit CW wave from any SG to Rx port on USRP-2900. (to test usrp can receive a CW wave). and you can use any Spectrum Analyzer.
Thank you.
06-26-2024 10:53 PM
I don't have spectrum analyzer. Instead, can I use GNU Radio software to check whether transmission is okay?
