USRP Software Radio
How to set active antenna for ni-usrp driver with basic RX/TX daughter board?
Hi, everybody
I have some problem in using basic RX/TX.
I could use RFX2400 with USRP by Labview to run the examples of NiUSRP.
However, I can't run the examples by using basic RX/TX rather than RFX2400.
The message of error is following:
Possible reason(s):
A runtime or configuration error occurred.
Code: 2638
Details: ValueError: no selectable antennas on this board
I had saw the article about this problem (click here), but i can't understand that because I'm a tyro.
Hence, I need your help. Thanks.
Mic Lin
(6,623 Views)
Hey Mic_Lin,
What antenna name are you using?  I am able to run a RX session with my BasicRX using RX1 or RX2 as the antenna name.  I am able to run a TX session using either TX1 or TX/RX for the antenna name.  I am using NI-USRP version 1.2 and I have also run this using version 1.1.  If you are using version 1.0, I recommend updating to a newer driver version.
Sarah Yost
Senior Product Marketing Manager
(6,615 Views)
Hi Sarah Y
Thank you for your help. I can run it now. I think my problem is that I installed the old version (NI-USRP 1.0) as you said.
Thanks again!
Mic Lin
(6,605 Views)
