USRP Software Radio
How to synchronize Tx and Rx USRP
I have two USRPs 2920. One is for Tx and another is for Rx. I want to know how I can synchronize both of  the USRPs two each other?
(4,812 Views)
Hello Joseph,
You can use a MIMO cable.  That will let you synchronize the clocks.  Below is a link you can use as a resource for single USRP synchronization to get your started:
https://forums.ni.com/t5/Software-Defined-Radio/Single-USRP-Synchronized-TX-and-RX-Finite/ta-p/35056...
Also, here are some resources that should help you out with your application:
https://www.ni.com/docs/en-US/bundle/ni-usrp/page/mimo-synchronization-for-usrp-292029212922293.html
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2rKCAQ&l=en-US
Jonathan R.
(4,786 Views)
