USRP Software Radio
LP0965 Antenna
Hi all !
I am quite new to the RF scene and have recently acquired a USRP B210 kit.
In setting up the kit I soldered an SMA connector onto the LP0965 antenna as suggested by the NI website.
After checking for continuity between the pins I found the middle SMA pin is shorted with the outer four pins of the connector.
I would just like to verify if this is the case before proceeding as I do not want to damage the USRP.
Many thanks!
Message 1 of 1
(1,650 Views)
