USRP Software Radio
MB EEPROM Must be Reprogrammed Error - Determining Revision Code
In reference to the previous solved thread https://forums.ni.com/t5/USRP-Software-Radio/EPROM-MB-must-be-reprogrammed-USRP-LABVIEW/td-p/3368253
I simply need to confirm if the revision table :
Is incremental i.e. in my USRP the revision is 154XXXK - 0XX
Does "K" equate to Revision 11?
Thanks in advance,
Tomi
(2,577 Views)
Tomi10,
Thanks for posting on our forums. It would seem that the answer to your question would be a simple yes, but because of the nature of the question, the only ones who could confirm this would be Ettus Research themselves.
I recommend you reach out to Ettus (support@ettus.com) and ask them confirm the revision number.
Patrick O.
Applications Engineering
(2,557 Views)
